What does it feel like to have a bad CV joint?
Old Jan 12, 2011 | 10:01 PM
joeytogo's Avatar
Default What does it feel like to have a bad CV joint?
What does it feel like to have a bad CV joint? Sometimes when I accelerate from a stop I feel a clunk in my 2005 s40.
Old Jan 18, 2011 | 03:24 PM
Scotland77's Avatar
More likely a bad ball joint, does the clunk happen when you first apply the gas??, does it also happen when you apply the brakes??
Bad CV joints tend to show up at higher speeds or when turning tightly such as in a parking lot
Old Jan 19, 2011 | 07:17 AM
joeytogo's Avatar
Default I haven't noticed it clunking on breaking.
I haven't noticed it clunking on breaking only when I take off. It also doesn't always do it. I'm not sure what could be the cause, but at least it works. The more pressing problem is getting my engine back together. The head is in a machine shop now. I'm not sure what all I should replace when I put everything back together. I know I should replace the head and manifold gaskets, but I don't know about the water pump, camshaft seals, and head bolts. Do you know why it is recommended that head bolts be replaced upon head reassembly? My old head bolts look like they are in perfect condition.
Old Jan 20, 2011 | 08:38 AM
Scotland77's Avatar
For sure you want to replace all of the gaskets you can, you probably also want to replace the timing belt, timing belt tensoiner and the water pump.
It's all about putting in a little money for parts now that are easy to replace when you have access to them, as opposed to putting the engine back together and then the water pump failing in 2 months and you gotta take it all apart again.
The head bolts are designed to stretch a little when they are installed the first time, so you should never re-use them.
And for sure you want to do an oil change after you get the engine all back together again, when you remove the head coolant can sometimes get into the oil passages and then you end up lubricating the engine with water. For sure change the oil
Old Jan 22, 2011 | 10:16 AM
joeytogo's Avatar
Default Machining the head?
Hi Again,
Thanks for all of your great tips. My cylinder head has been disassembled at a machine shop and they said it wasn't cracked. I did need to replace all 10 of the intake valves. I ordered these myself and am going to deliver them to the machine shop. The guys at the shop said they weren't able to find the clearance measurements for the tappets (cap like things that go over the valves). Do you know where I could find this information? Also, do you have any sort of idea of how much I should expect to pay the machine shop for their labor? I asked them for an estimate, but they said they couldn't really answer yet.
Thanks again, JB
Old Jan 23, 2011 | 07:04 AM
Scotland77's Avatar
What size engine??
Old Jan 24, 2011 | 07:33 AM
joeytogo's Avatar
Default 2.4 l
2.4 l
dpvovo
Feb 18, 2019 07:41 PM
fuller0554
Feb 19, 2013 07:01 PM
LPG Karl
Aug 25, 2009 10:20 PM
jman7310
Apr 30, 2009 08:22 PM
