Whirring sound after start up and during reversing
Old Jul 14, 2017 | 08:55 PM
Mike Frazier's Avatar
Default Whirring sound after start up and during reversing
I have a 2000 S40 and noticed that there is what sounds like a whirring sound coming from the front of the car (or maybe the dash or center console) after startup and sometimes when reversing. It lasts for about one second and occurs several times. It sounds like an electric motor. Could it be the auto climate control opening or closing a valve? I'm wondering about that because the air recirculation is stuck in the open position.
I've had this car for only a few months so I don't know how long this has been going on. And it's my first S40...quite a change from the 1984 240 I've been driving for 26 years!
Thx.
Old Jul 16, 2017 | 05:28 PM
I can't think of anything that going into reverse would have to do with a whirring sound - perhaps its just the timing of you shifting gears or going into gear is dropping the system vacuum and the aux vacuum pump is kicking on. On my 2000 S40, The vacuum pump kicks on and off a few times after a cold start to build up brake booster pressure. Its possible you could have a blend door motor trying to sync itself. Rather than a stuck door, I'd suspect the actuator arm from the motor to the door may have unhooked itself.
Old Jul 25, 2017 | 07:27 AM
Hudini's Avatar
Agreed, vacuum pump for the brake booster. This is assuming it isn't the condenser cooling fan for the A/C system. This one should be pretty loud but totally normal if your A/C is on.
Old Aug 1, 2017 | 11:36 PM
You're right. It must be the vacuum pump for the brake booster, of which I didn't know it had! It only makes that sound when my foot is on the brake.
Thx!
fluffernutter
Jun 28, 2012 07:11 PM
dcb
Dec 26, 2010 10:24 AM
hollymight
Dec 3, 2010 06:23 PM
redeyereeves
Jun 10, 2010 09:19 PM
Sabre
Jul 8, 2008 08:28 AM
