Window Regulator for 2002 Volvo s40
Old Mar 20, 2021 | 01:53 PM
Newport_j's Avatar
Default Window Regulator for 2002 Volvo s40
I am trying to find a window regulator for a 2002 Volvo s40. It is for the rear seats of the car behind the driver; the left hand side rear window regulator. So far
wherever I looked Amazon, Advance, O'Riley simply cannot get one. It is not too hard to get a window regulator for the from seats, but try to get one for the rear seat behind the driver,
that is a different story altogether.
Any body have any idea where I can find one? I would sure appreciate it.
R,
Newport_j
Old Mar 21, 2021 | 12:00 PM
habbyguy's Avatar
Have you considered replacing just the motor (if that's the problem)? It looks like it's the same for the front and rear, and is available (about $75 from rockauto, for example).
Otherwise, a boneyard or eBay would probably be your best bet.
Old Mar 22, 2021 | 07:36 AM
Newport_j's Avatar
When I press the key to raise or lower the window, I can hear the motor running. I am assuming that means it is okay. I jus wanted the window raised u[ and completely shut. Whoever uses that window in the first place?
The mechanic said that if you are going to rewove the door panel, you might as well replace the regulator since you are going to all of that trouble. He has a point. I just cannot find the d**m on any website. Not for love or money.
Respectfully,
Newport_j
Old Mar 22, 2021 | 11:46 AM
habbyguy's Avatar
Like you said - no one uses that window very often, so I'd just use the eBay link I provided and find a used one, swap it in and call it a day. Easy peasy, and pretty cheap, too!
Newport_j
May 10, 2016 11:06 AM
Newport_j
May 2, 2016 02:34 PM
Newport_j
Apr 19, 2016 01:10 PM
Wifes_S60
Apr 30, 2011 09:32 AM
volvo-man
Dec 22, 2009 06:54 PM
