Ac/heater blower runs when engine is off
Old Apr 25, 2009 | 05:51 PM
marko's Avatar
Default Ac/heater blower runs when engine is off
I just shut my 2004 S60 off and the ac blower motor is still running. And now the ac is not working? This has never happened before...HELP
Thanks, Mark
Old Apr 25, 2009 | 06:31 PM
Johnny Mullet's Avatar
Some Volvo models have the interior blower motor come on with the car off to cool the cabin. Are you sure your A/C is not working now while you are driving.
Old Apr 25, 2009 | 06:43 PM
sml's Avatar
sml
It is normal for the blower to run when the car is parked and the keys are in your pocket.
Something to do with drying the AC lines.
Now ... as for why your AC is not working, I have no idea.
Old Apr 25, 2009 | 07:38 PM
marko's Avatar
I also thought that this could be normal so I waited 1 hour...still running. So I pulled the fuse (so my battery doesn't die) and waited 3 hours, put the fuse back in with the car still off and the blower fired right up as soon as I plugged the fuse in. It will not stop running???
Old Apr 25, 2009 | 08:08 PM
marko's Avatar
New problem, now the blower doesn't run at all
Old Apr 25, 2009 | 09:27 PM
Maybe the fan resistor went bad.
Would be best to have the A/C codes pulled.
Old May 21, 2009 | 08:28 PM
vvod's Avatar
Default I have the Same Problem
I've got the same problem happening right now with my 1996 850
I turned the car on and off several times, left it running for 30mins then pulled the fuse.
Where should I start looking for source of the problem?
Old May 21, 2009 | 08:29 PM
The blower motor resistor might be bad.
Old Jun 12, 2009 | 11:37 AM
Akahil's Avatar
If the resistor is on the motor, it is not the problem. I have the same problem and replaced the motor and have not solved the issue. Otherwise where is the resistor?
Old Jun 15, 2009 | 07:07 PM
If yours is a 01 then it is in the housing with the blower motor.
Old Jun 16, 2009 | 01:05 PM
marko's Avatar
Okay, I have been playing the game of pulling the fuse for about two months now. I think it's time to finally figure this out....where is the resistor on my 04'? Is it part of the blower?
Thanks, Mark
Old Jun 16, 2009 | 07:59 PM
Kind of you have to remove the blower motor to get to it.
Old Jun 19, 2009 | 11:04 AM
855turbo95's Avatar
Is there a writeup/video of this process floating around anywhere? Thanks.
Old Jun 19, 2009 | 07:12 PM
Not that I have seen yet.
Old May 26, 2011 | 08:23 PM
nemotode's Avatar
Default AC on when engine off
My 2004 S60 AC comes on when the engine is off and the keys are in my pocket. I know it's normal to have a short on time to dry out the AC lines, but mine sometimes goes for an hour or more. It usually does this after I have left the car and its vicinity, thus draining my battery. It is sporadic. It seems to happen more in the summer. Does this still sound like the blower motor resistor?
Old Jun 4, 2011 | 11:41 PM
volvomans60's Avatar
It can take sometime. It can be annoying. It has to dry the evaporator. A volvo dealer can disable this for you.
Old Aug 2, 2011 | 10:55 AM
  #17
Tcappy's Avatar
Is this something that only a volvo dealer can do (computer reprogramming) or can any "Joe" mechanic do it? If so please let the rest of us know so we don't get raked of the coals by the dealers.
Thanks
jjh92
Feb 17, 2024 09:59 AM
ltpreston
May 30, 2023 01:33 PM
theman
Oct 10, 2013 05:29 AM
pdx
Oct 30, 2012 03:46 PM
Wanttobecool
Mar 11, 2009 07:21 PM
