Changing Radiator
Old Aug 13, 2012 | 09:13 PM
newbie 42's Avatar
Cool Changing Radiator
Can someone kindly explain the procedure for changing the radiator on 2001 S60. Thank you
Old Aug 14, 2012 | 05:24 PM
MYS6T's Avatar
Here you Go Fixing a Leaking Radiator
Old Aug 15, 2012 | 04:17 PM
newbie 42's Avatar
thank you so much.. So the radiator does slide out from the bottom..?
Old Aug 17, 2012 | 08:59 AM
sgreenfield's Avatar
Yes, it can if you do it this way you will need to jack up the car and I recommend having an assistant for the extra eyes as well as the hands. It will come out as a "sandwich" with the condenser and the intercooler (If you have a turbo). I just did this two weeks ago with my wifes help. Good luck!
Old Aug 18, 2012 | 07:27 AM
newbie 42's Avatar
Thank you for your replies... So I installed the radiator and now the car won't turn over.. it seems like its not getting gas . I changed the battery on it because it died out on me. I put a voltage meter to it and it was 4 voltage. So I put a new one. The car cranks but does not turn over. Also how do I replace the ATF .. thank you guys..
mikeawd850
Nov 30, 2012 02:26 AM
doddj22
May 8, 2009 09:38 PM
aruizdelhoyo
Jan 22, 2009 04:46 PM
ldncars
Engine & Internal
Mar 4, 2005 10:33 AM
timbo
Oct 27, 2004 09:27 PM
