01 S60 2.4T..when I cold start I hear exhaust leak at front...
Old 06-27-2009 | 09:34 AM
426HPSS's Avatar
Default 01 S60 2.4T..when I cold start I hear exhaust leak at front...
after running a few minutes you cant hear anymore when you stand outside...down pipe?? exhaust manifold?? looked at exhaus when we were doing trans fluid and everything looked tip top but cant see from top of engine down to bottom of car too well...
Any common maladies??
Old 06-27-2009 | 09:59 AM
My bet is exhaust manifold gasket. Seen it many times.
Old 06-27-2009 | 11:04 AM
426HPSS's Avatar
what is involved?? how expensive?? How much time should a shop be quoting me??
Old 06-27-2009 | 11:10 AM
They will basically charge for removing and installing turbo/manifold. Most likely about 3 hours labor.
Old 07-02-2009 | 08:13 PM
mrutherford2005's Avatar
It has happened to me, covered under warranty though. Happened after it sat for a measly 3 days.
Old 11-03-2009 | 07:52 PM
sy381's Avatar
Im having this same problem with my wifes 02 S60 AWD Turbo. Called my local volvo dealer to ask them what it would cost to do the job. They said 6 hours labor and parts. They told me they have never saw this problem.
I think im going to try the job myself. What should I have ready to do the job as for as parts go. Im worried about studs breaking off. Should I have a few available?
What are the torque specs on the turbo bolts, manifold bolts, etc. What all has to come off to get the job done so I dont remove more than i have to. Thanks in advance
Old 11-04-2009 | 08:27 PM
I would get a few nuts and studs as spares.
Remove the turbo return line. Then you should be able to remove the extra bracket from the turbo to the motor and then all the nuts. That is for the manifold. Then you should be able to work it out far enough to change the gaskets.
tbcpat
05-17-2014 09:28 AM
IronLung
10-07-2007 09:51 AM
Dainos
09-14-2007 07:39 PM
sedonasunrize
09-03-2007 10:24 AM
Quick Reply: 01 S60 2.4T..when I cold start I hear exhaust leak at front...
