92 jumped #4 hear pump will not start
Old May 8, 2014 | 08:42 PM
tbcpat's Avatar
Default 92 jumped #4 hear pump will not start
Hi I have a 92 240 just stopped in traffic.
I have looked at lots of threads and did some trouble shooting. Fuel rail has a valve that just sperts a little after turning key on.
I just jumped #4 fuse and can hear a buzz. Still will not start. just spins enthusiastically
Any Ideas?
Old May 15, 2014 | 02:58 PM
Welcome to the forum. Moved this from "New Member" as that is a place to introduce yourself and your car but not for technical assistance. Hopefully someone here with a similar model will be able to help you out.
Old May 16, 2014 | 06:18 AM
act1292's Avatar
Check to make sure your timing belt hasn't snapped. Take off the oil cap and have a buddy crank the engine. Look into the top of the engine and you should see the cam shaft turning as the engine is cranked. If it doesn't turn, then your timing belt needs replacing.
Old May 17, 2014 | 09:08 AM
tbcpat's Avatar
Default Volvo canundrum
The first thing I did was check for spark -- good spark. Then I started checking the fuel system-- fuel at rail I went back to spark and got no spark but had juice to coil and beyond.
As suggested I checked the timing belt-- broken
I assume it had jumped at first giving me spark but out of time. The next time I tried to turn over the belt must have just broken. Leaning me with no spark.
I had a buddy come over and we replaced the timing belt and tensioner and it runs fine.
The tensioner was rough and that may have been the major contributor to the belt breaking.
Thanks for the input.
Pat
Old May 17, 2014 | 09:28 AM
Life is good !!
WilliamGWilliams
Dec 9, 2012 07:59 PM
426HPSS
Nov 4, 2009 08:27 PM
dlenn
Dec 15, 2008 09:30 AM
tr_car_nut
Nov 1, 2008 08:45 PM
montysano
Mar 9, 2007 10:13 PM
