'02 S60 needs ring gear
Old Sep 28, 2010 | 06:16 PM
rickt's Avatar
Default '02 S60 needs ring gear
148K on my '02. Getting metal shavings on the crank sensor causing starting problems. Shop says I need new ring gear and starter which requires pulling the tranny....$$$$
I've replaced ring gears on my old Chev 350. How involved is this for a DIY project???
Thanks!
RT
Old Sep 28, 2010 | 07:12 PM
ed7's Avatar
ed7
With that mileage you'll have some shards on the pick-up. Unless you have gaps/missing teeth on the gear or other cranking issues, blow the shavings out of the bell housing and keep on going.
Otherwise, it's a major/expensive pain, R&R the flywheel and starter.
How do you get to the flywheel? Take a wild guess.
ED7
Old Oct 4, 2010 | 11:31 AM
rickt's Avatar
Got it...any idea on accessing the cam position sensor to wipe it off? They said it's magnetic so the shavings build up on it and interfere with starting.
Thx,
RT
Old Oct 4, 2010 | 08:23 PM
ed7's Avatar
ed7
They pulled it to clean it already, yes?
There should be a lower cover on the bell housing to open.
Pull both and blow compressed air with a long schnozzle in the top and out the bottom to push the chips out, wipe the sensor and back together again.
You'll get most of it.
ED7
Old Oct 7, 2010 | 08:47 PM
rickt's Avatar
Yes, they have. Thx for the info!
RT
tech
Jul 31, 2020 09:15 AM
Schaeffy
Jan 8, 2014 06:36 PM
carlheat
Oct 25, 2010 10:36 AM
dror_idn
Oct 28, 2009 04:39 PM
