04 S60R manual transmission adjustment
Old May 18, 2018 | 07:28 AM
malcolmtent's Avatar
Default 04 S60R manual transmission adjustment
I left my 04 S60R with 6-speed manual transmission parked for 16 days while I was away on vacation. The transmission was gorgeous when I left, but now I'm having problems getting into any of the even numbered gears (ie 2, 4, 6, and R, the ones I pull into rather than push). The odd numbered gears (1, 3, 5) are all fine, and the problem is on both up- and down-shifting. Double clutching seems to help (maybe). I can get it into gear with a little difficulty, sometimes with a little crunch, but it doesn't slip out once it's in there.
What should I look at?
Lubrication? Where?
Adjustment? How?
Of course, the left-it-standing-for 16-days could just be a coincidence.
Any thoughts would be appreciated.
Old May 18, 2018 | 10:30 AM
Default ABS module is currently out of the car, if that makes a difference
I forgot to mention that the ABS module is currently out of the car - it's at a repair service. I doubt that it would be causing my issue but thought I'd mention it in case.
MaxDec
Apr 28, 2017 02:05 PM
clamjuice
Jul 19, 2016 05:48 PM
pistorman
Jun 23, 2013 11:37 PM
Donzi
Nov 5, 2012 10:27 AM
nextproject
Nov 16, 2009 07:04 PM
