'05 2.5T AWD Can I do the shocks?
Old Jul 18, 2015 | 03:09 PM
LiteWait's Avatar
Default '05 2.5T AWD Can I do the shocks?
Never replaced shocks before, is this a DIY job? Any tips on how to do it on this model?
Old Jul 22, 2015 | 07:55 PM
volvotech1's Avatar
I'm assuming you're referring to the rear, and yes they're easy. If you want to replace the front struts you'll need a spring compressor or quick struts. If you do the front struts replace the seats also, they fail far more often than the struts.
Old Jul 23, 2015 | 05:31 PM
LiteWait's Avatar
Well now that I learned a bit, they don't look that easy. The AWD models require a spring compressor it seems in the rear as well. Certainly easier than the fronts, worried when I remove the spring/shock the control arm and hub is just going to flop. If someone has link to a DIY guide I'd appreciate it. Thanks.
Old Jul 24, 2015 | 01:44 PM
mainesail's Avatar
The service manual is available on eBay. You can often rent a spring compressor from Auto Zone or the like. I tried it on our Caravan which has very heavy duty springs and decided that if I wanted to live a long life, I'd have someone else do the spring replacement.
Old Jul 26, 2015 | 09:07 PM
volvotech1's Avatar
You're right, I figured someone made a rear quick strut. I'm biased, working for a dealer, but use genuine Volvo parts, whether relabled or not, but make sure you get OE parts.
Old Aug 1, 2015 | 05:01 PM
heyitsmebobbyd's Avatar
are the Monroe c2501 struts and the c1501 shocks the exact same as the volvo oems?
umbalaxx
May 31, 2015 12:32 PM
jocoman
Apr 13, 2015 10:26 AM
jared..mann
1998-2000 model year V70
Apr 20, 2013 04:33 PM
parrym
Jul 13, 2007 12:51 PM
daver80
Nov 2, 2006 07:35 PM
