05 S60 2.5T AWD: P0700 "Transmission Control System (MIL Request)", P0600 "Serial Com
Old Jan 10, 2016 | 05:11 PM
psamanni's Avatar
Default 05 S60 2.5T AWD: P0700 "Transmission Control System (MIL Request)", P0600 "Serial Com
Hi all, if you remember from a previous thread, I previously had a set of warning and error messages thrown at me ("immobilizer, see manual", "transmission service required", "engine system service required"), on a dying battery. I was fine until last night, when, as I downshifted to 4th gear, I got "Anti-skid service required", immediately followed by the RPM counter falling to 0, and "Transmission service required". At that point, the transmission was stuck in 4th, then I got the "-", before the transmission got back to "D" 5mn later, and the Check engine light came up.
Over the last few months, the "Anti-skid service required" and "Brake assist service required" warnings have come on and off, intermittently. I had figured changing the right front half-CV axle in October would take care of this, and it seemed to for a while, but no. The car drives perfectly fine.
The error codes I got from my Android app are: P0070 "Transmission Control System (MIL Request)", P0060 "Serial Communication Link", P0503 "Vehicle Speed Sensor Intermittent/Erratic/High".
Any idea/suggestion is highly appreciated, thanks!
Old Jan 11, 2016 | 07:12 AM
pjsmithres's Avatar
Maybe there is an AAMCO transmission place that would read/interpret.
There is a local Transmission place in San Diego that will read the codes for free. They will also give free quotes to "fix"
Old Jan 11, 2016 | 11:56 AM
psamanni's Avatar
Thanks for the advice! Looks like I'm getting my own Vida/Dice solution, since getting the diagnostic at a non-dealer shop is $108. Seems pretty steep.
Old Sep 3, 2019 | 10:23 AM
byobfreebeer's Avatar
Question P 0700, p 0600, p 0503
My '06 S60 has the same set of codes and seems to be in limp mode (only driving in 1st and 2nd gear in manual shift mode).
Put in a new battery (which the car needed) but that didn't change any issues with those codes.
Have you fixed your car?
What was the problem?
mymomhadthis
2001-2013 model year XC70
Jan 4, 2018 02:28 PM
psamanni
Dec 15, 2015 05:28 PM
Akki
Aug 28, 2015 11:55 PM
SilverBus
Oct 20, 2009 09:41 AM
chrissygm
Sep 30, 2008 05:53 PM
