14 Volvo S60
Old Jul 30, 2019 | 12:59 PM
George Howe's Avatar
Default 14 Volvo S60
Right around 68k miles. Car runs great, but burns oil. Have to add quart or 2 between oil changes. (7500 miles) After researching is it worth to repl pcv valve 1st to see if it helps.
Old Jul 30, 2019 | 01:19 PM
consuming a quart every 3000 miles is not considered problematic albeit its kind of annoying. There are some service bulletins for 2012 to 2016 S60s so you may want to check in with the dealer to see which apply to your car. Do you see any signs of weeping or leaking? There is a general history of this generation of cars having oil consumption issues - not sure if its due to rings/valve guides/seals etc but worth googling for background.
The car doesn't have a PCV valve per se like your mom's old Buick, it has a breather system with hoses from the block that feed an oil separator that returns the oil back into the crank and sends the blowby gasses back into the intake. Should the PCV breather system clog, you will build up positive crank case pressure which after time can push out seals (generally starting with cam seals) causing leaks. A simple test is to put a latex "surgeons" glove over the oil filler neck and if it inflates with the engine running you have positive crank pressure. (check out youtube for vids on this test).
subzerocarfanatic
Oct 11, 2019 08:20 AM
Matt98svt
Feb 9, 2017 08:10 PM
KRCrisp
Mar 13, 2016 07:44 PM
pyro71
Jun 20, 2013 07:56 PM
97850glt
Oct 16, 2010 09:56 AM
