2 wires going to the air filter box
Old May 27, 2011 | 07:47 PM
Porkchop99's Avatar
Default 2 wires going to the air filter box
Can anyone indicate what the 2 connections to the air filter box are for. I happen to be missing one that came detached I happened to notice.
Thanks!
Old Jun 3, 2011 | 07:02 PM
Porkchop99's Avatar
Anyone know what I'm asking?
Old Jun 4, 2011 | 12:00 AM
J. A. Higgins's Avatar
As far I know there is nothing connected to the air box other than the three clips that hold the top cover. There is a connector for the M.A.F. sensor, which is in the tube just off the air box.
Old Jun 4, 2011 | 12:01 PM
ArmadaS60's Avatar
I know exactly which ones your talking about. They always come off when i change my air filter. Your talking about the two little hoses that attach just behind the air intake box? Im not sure what they are for but they are really annoying
Old Jun 5, 2011 | 02:59 PM
Porkchop99's Avatar
Default Yes those!
Those are the ones. They must serve a purpose. ??
Old Jun 6, 2011 | 10:25 AM
ArmadaS60's Avatar
Apparently they are for the vacuum system, or monitoring air flow. The guy I talked to didn't have a solid answer but he did say it shouldn't cause any problems if you can't reconnect them. Hope that helps
Old Jun 7, 2011 | 08:19 PM
Porkchop99's Avatar
ok, I just cleaned my MAF but the idle still fluctuates a bit like when I am at stop lights. I thought maybe these wires played a part.
Old Jun 8, 2011 | 03:49 PM
NJGreenBudd's Avatar
wires or hoses? is is possible for you to take a picture of what you're seeing as I have never seen anything like this on mine or others.
Old Jun 13, 2011 | 08:10 PM
Porkchop99's Avatar
Default foto here to help explain
hope this helps
Old Jun 13, 2011 | 08:12 PM
Porkchop99's Avatar
hope this helps
Download wopp.JPG for free on uploading.com
PS, I need a better free files share site :-(
Old Jun 13, 2011 | 08:42 PM
537playing's Avatar
Those hoses are to adjust the air flowing thru the air box. When the temp is low, a door stays open to allow hot air from your exhaust heat until your engine warms up. When the temp rises, the door swings to shut the flow of hot air and allow colder air from the front vent by the radiator.
Old Jun 14, 2011 | 01:55 PM
S60man's Avatar
For pictures use photobucket or imgur.com
Old Jun 18, 2011 | 03:13 PM
yeah photobucket is much easier than whatever that was.
I hadn't seen those before, must be for non turbo only, no?
debargha
Feb 24, 2015 10:46 PM
AlexCurran1
Jun 22, 2011 12:15 AM
S40 Wheelman
Jan 12, 2011 07:09 PM
Mr Zed
Aug 12, 2005 01:18 AM
