2001 S60-Strong gas smell/rough start
Old May 17, 2019 | 12:55 PM
Kygar004's Avatar
Default 2001 S60-Strong gas smell/rough start
Hi all.
I've had an issue for the last couple of weeks with a strong gas smell in my S60. It smells from the outside, as well as in the cabin and trunk. Also, it seems to be just as strong in the cabin after sitting overnight as after driving it. It gets way better when running the air vents on high, so I'm fairly certain that it isn't leaking under the hood anywhere. Also, there is no visible gas leak on the ground underneath the car. It's also been starting a little rough within the last few days, taking a few seconds to turn over. I'd love to fix the problem myself, but I'm just wondering where to begin troubleshooting? Is getting a smoke machine to test for vapor leaks a reasonable start? If so, where is my entry point on the car to smoke the system? And if not start there, where should I start? Thanks guys.
-Kyle
Old May 17, 2019 | 01:18 PM
ES6T's Avatar
Most common problem with those symptoms is a leaking fuel pump.
Pull the rear seat, remove the passenger side access cover and inspect.
Old May 18, 2019 | 09:47 AM
Kygar004's Avatar
It most definitely was the fuel pump! Thanks.
Roosterv
May 25, 2019 07:16 AM
petergreene
Jun 15, 2015 01:53 AM
Ahmed
Jun 6, 2011 08:41 PM
blamj
Oct 29, 2009 02:28 PM
rene
Jun 20, 2007 07:16 PM
