2001 S60 turbo possibly bad
hi,
I am looking at a 2001 s60 from a friend of mine and he thinks the turbo might be going bad,
1st off how hard are they to replace? my mechanic said it was a PITA and the turbo runs you $2000 is this right?
2nd how can I tell if it has a bad turbo? any tell tell signs when i drive it?
3rd can i drive it with a bad turbo if this one is bad?
finally any ideas on the value of the car I was thinking like $3500 with a bad turbo but does that seem right??
Any help would be much apreciated
you can drive it but it'll lack power and you will get CEL lights
the turbo can be rebuilt for less than 1k and its actually pretty easy to replace
if you drive it and go into boost and you hear fan like buffering then it's likely bad but if you hear a faint dentist drill noise its probably ok
the only way to really know is to take of the intake hose into the turbo and wiggle the turbo shaft you will get some play but if you feel the turbine blades touch the housing rebuild it immediately because if the housing gets damaged (from driving with a bad turbo) you will have to buy a new unit.
if it is bad I would look for a turbo from a junk yard, send it out for repair and then install it when you get it back, then send yours in for repair and have a backup or sell it to pay for repairs.
also the price sounds right, a little low actually which benefits you because it might just be a turbo control solenoid and that's an easy fix
Thanks for the input,
My mechanic said that when he did one that because of piston slop and lack of oil changes that the oil foams up and he had to use compressed air and blow the passages leading to the turbo get clogged.
He said even after two times with the oil pan off and blowing those passages clear that the car would loose oil pressure after flooring it. Does this happen alot or was that just a freak thing?
You can replace the center section of the turbo or "cartridge". A turbo shop should charge around $750.00 if you take them the turbo. There are o-rings that seal the oil pickup in the pan. They get hard at around 100,000 miles and let the oil pump draw air causing low oil pressure. It's not a bad job to drop the pan and replace the seals. The turbo is made by mitsubishi
shoeboxOH
2001-2013 model year V70
03-30-2014 03:21 PM
Mike740Turbo
07-04-2012 02:53 PM
guest01
05-23-2011 07:47 PM
nscoville 87' 760
06-10-2010 12:27 AM
