2001 Windows won't go down all the way.
Old Nov 16, 2008 | 08:06 PM
Modifier's Avatar
Default 2001 Windows won't go down all the way.
Hey all,
I have a 2001 S60 T5. Just had to replace the battery, hoping that would fix my window problem...but it didn't, I still needed a new battery anyways. When I hit the button to roll down my window, it only goes down about 20% then stops. This occurs with all of the windows except the sunroof. When I roll it back up with the button, the window will go all the way up, but then try to come back down20%. I have to hold the button for a couple of seconds in the 'up' position to keep the window up.
Any advice on what this is would be greatly appreciated!
Old Nov 17, 2008 | 01:00 AM
D_Jack's Avatar
Default RE: 2001 Windows won't go down all the way.
the car is confused about how far down is down.. a lot of the new toyotas are like this as well.. im not sure how to do it but there is a way to put it into learning mode .. also try using them without pushing them all the way down as to trigger the auto up and auto down part to troubleshoot the motor in the door..
Old Nov 17, 2008 | 08:29 AM
Manually move the window all the way down with the switch hold the switch 10-15 seconds. Then manaully move it all the way up again holding the switch up 10-15 seconds and see if that resets it.
If not then the dealer will need to do it.
kwatt
Nov 3, 2013 09:40 PM
Trejor
May 27, 2011 08:06 PM
Business_Socks
Jan 7, 2009 04:05 PM
cm123
Sep 19, 2008 07:20 PM
bardejov
Jan 13, 2007 07:49 PM
