2002 base model--where is that purge valve?
Old Oct 7, 2018 | 07:02 AM
John Roden's Avatar
Default 2002 base model--where is that purge valve?
I found one in the junkyard in 2 seconds, but I can't find the location on my 2002 NA base model, looking on driver side down under the airbox but I don't see it, it it elsewhere or hidden of something?
Old Oct 7, 2018 | 09:29 AM
John Roden's Avatar
never mind! Found it clipped onto the fan shroud
Old Oct 7, 2018 | 01:12 PM
tony1963's Avatar
You went to a junkyard to buy a $10 purge valve for a 17 year old car????
Old Oct 7, 2018 | 01:23 PM
John Roden's Avatar
Yes exactly and to make matters worse the one that I got doesn't fit. But they just gave it to me along with the gas cap so no big loss. I think I'm going to check that j-shaped hose that goes to the charcoal canister before I spring 30 bucks for the purge valve I hate to just troubleshoot by throwing money at a problem
Old Oct 7, 2018 | 03:19 PM
tony1963's Avatar
Well, it is closer to $30 than I anticipated. That small hose typically rots out and can cause the problem. What code did you get?
https://www.rockauto.com/en/moreinfo...030105&jsn=327
Old Oct 7, 2018 | 03:45 PM
John Roden's Avatar
mine has two skinny hoses going to it. I replaced the vac hoses going to the valve as they were a mess, then i reset the code but it takes a while to return, it's the 45 code I believe for "gross leak". I replaced the gas cap with a junkyard find.
Is it a better method to fix then see if the light goes off or fix and reset the code and see if it returns? Wish I had one of those smoke machines.
lfc2
2001-2013 model year V70
Sep 10, 2012 02:02 PM
W35
Mar 7, 2010 11:08 PM
holobox
Sep 28, 2009 08:04 PM
scubatelco
Sep 7, 2009 07:54 PM
drizzledazzle
Oct 9, 2007 06:31 AM
