1998 S40 T4 mis-fire, poor idle, lack of power under load!
Old Feb 3, 2007 | 01:08 PM
johnwilton's Avatar
Default 1998 S40 T4 mis-fire, poor idle, lack of power under load!
I recently (last week) bought a stunning S40 T4 (1998) is has a full volvo service history with the last service performed just 3000 miles ago. It is one owner at is on 109000 miles.
When testing the car it held back a little when I put my foot down but decided that was probablydue to plugs and HT leads. I bought the car and took it for a nice long drive a couple days after purchase. During the ride the problem got increasing worse specifically under the load of rapid acceleration.
It then got to the point where its idle was abismal and sounded like it was not firing correctly.
I have just replaced the plugs (which were awful) and coil packs (with 2used ones which I have been assured work) It is still running badly. The plugs get wet foul with oil almost instantly. I have adjusted the gap of the plug (0.2 mm as per the book) but no luck. The HT leads look fine but have not replaced them yet as the local car shop ordered me the wrong set....
Any suggestion before I run back to Volvo and admit defeat. (I may need a small bank loan if they get their hands on it)
Old Feb 3, 2007 | 01:14 PM
johnwilton's Avatar
Default RE: 1998 S40 T4 mis-fire, poor idle, lack of power under load!
I should add that I get lots of wet foul on plugs 1, 3 and 4... 2 is pretty clear.
Old Feb 3, 2007 | 01:15 PM
Any idea where the oil is coming from?
Replace the leads.
Old Feb 3, 2007 | 01:19 PM
johnwilton's Avatar
There was alot of oil around the original 3rd plug when I removed it, plus the electrode were vitually detroyed... There is a oil around to top of the head which I felt was unusual on the right hand side.. Not sure where that was coming from.
Old Feb 3, 2007 | 01:24 PM
johnwilton's Avatar
Will the plugs foul if they're not firing properly?????
Old Feb 3, 2007 | 01:28 PM
Most of the time yes but mainly if you run it for a long time like that.
Try replacing the oil cap seal and see if the oil stops leaking.
Old Feb 3, 2007 | 01:34 PM
johnwilton's Avatar
Thanks, I will visit Volvo for leads on Monday and keep you informed, typical! First my bike then my car.... Oh well. Glad I don't own a plane...
Old Feb 6, 2007 | 02:09 PM
johnwilton's Avatar
No Luck - So Far new plugs, coil packs and HT leads.....
It still runs on 50% power and rattles like an old woman.....
Any ideas? Does anyone know the symptons of head gasket failure?
Old Feb 6, 2007 | 04:32 PM
johnwilton's Avatar
I checked the coil packs and there seems to be a good spark from each but the timing seems intermitant...
I keep reading about having the 'codes pulled' and I guess this means taking the car to Volvo to get their computer to run a fault diagnosis. (would that be available on a 1998 S40?)
I have replaced both coil packs with other 'used' coil packs but they all seem to be ok...
This is really becoming a nightmare....
Old Feb 6, 2007 | 05:09 PM
johnwilton's Avatar
Old Feb 6, 2007 | 09:09 PM
How many miles were on the old coil packs?
They are a very common problem on these cars.
Old Feb 7, 2007 | 03:52 AM
johnwilton's Avatar
I don't know how many miles? I need tophone volvo to find that out which I will do today... I have already bought 2 coil packs from ebay but I know they were 'used'. I guess there is a chance they were damaged too. It there something before the coil packs which would effect the regularity of the spark etc?
Old Feb 7, 2007 | 09:00 PM
Nothing that is common.
Nothing that I have seen before.
Old Mar 16, 2007 | 06:52 AM
johnwilton's Avatar
You will all be pleased to know that I am rolling again. However it has come at a price. 2 blown valves and a cracked head. Total was £1300 (about $2500).
autoking
Jul 28, 2012 09:39 PM
West
Jul 25, 2012 12:03 PM
rvinson2
May 26, 2009 07:09 PM
azmark
Jul 21, 2005 11:39 PM
