2002 s60 2.4t w/ stc
found a couple of places that will rebuild if i remove and ship to them ( one at 400 the other at 540) plus shipping. any input on this option? no way to power off the warning light ( fuse)? does odometwer power circuit pass thru abs module ? speedometer functions even when odometer doesn't .
That is your best bet. Had a family member do that for his S80 and when it came back, it worked just fine. I know when the abs module starts to go, it causes all kinds of electrical problems mainly in the information cluster so the odometer is probably another symptom of a failing abs module. You can try and pull out the fuse and replace it with another one for a quick fix before you send in the abs module.
searchlight55
06-10-2014 11:34 AM
