2002 S60 with "slipping" transmission.......
Old Feb 20, 2011 | 09:31 AM
jimduke's Avatar
Default 2002 S60 with "slipping" transmission.......
When I change from reverse to drive there is a lag before the transmission goes into drive.
1. 165,000 miles - automatic transmission - 2002 model
2. Had Volvo change the fluid last month - beginning of problem
3. Have checked the fluid level per manual 3 times - always correct.
4. When it does go into drive there is not a "bump" or any unusual noise.
Any ideas?
Thank You in advance - Jim
Old Feb 22, 2011 | 08:43 PM
KeithS60&V70T5's Avatar
I have the same problem, ever since I let a service bay flush the fluid in our first Volvo V70. We bought it used and it already had 85K miles at the time. We have not fixed it yet and fear the worst. I am having it checked out in a week at the dealership and will let you know what they say.
Old Feb 23, 2011 | 01:23 PM
machinit's Avatar
If the tranny is bad, the cost for a remanufactured unit for that car is about - hope your sitting down - $5,700.00 just for the transmission.
I'm going through the same issue right now. I have a 2001 S60 and the damn car is worth less than the cost of a replacement transmission.
I'm currently looking to buy a different car and part mine out.
Old Feb 25, 2011 | 06:14 PM
an9rea's Avatar
Wow Jim, I'm having the same issue with a 2002 S60 @ 165,000 miles that just had a transmission flush a few months ago... but I don't actually feel any signs of issues when I drive my car...
https://volvoforums.com/forum/volvo-s60-v60-10/transmission-service-required-code-50782/
I hate how common this issue is --- it makes me think that my car is going to break down at any moment.
-Andrea
Old Feb 28, 2011 | 05:28 PM
zmantwo's Avatar
my car also has the same problem with the slipping I have been driving it like that for 1 year. I also had it flushed out made things better for a short time. But when I had to bring it to a dealer for some other problem they said Volvo does not recamend getting the trans flushed.
Old Sep 23, 2021 | 04:39 PM
Csukatamas's Avatar
Default Mr Tamas
I'm sure the gearbox is OK. It's a closed hydraulic system. In terms of moderate driving lasts a lifetime . Excessive driving also fine as long you do a double flush FULL change of fluid as per every 60K. Most people change it with leveller only. Also every flush been engaged every gear for 10-15 second. with running engine. The last level set by 60 Celsius . There is no filter fitted but a debris settle chamber relased with the full drain bolt.
jeffrisley
Jun 14, 2015 01:48 PM
Jeffmo1
Feb 20, 2015 12:08 PM
david87
Dec 28, 2011 08:43 AM
rbwhitt
Feb 27, 2006 01:25 PM
