2002 S60, Transmission Service Required ....
Hi, all!
So... I don't know if anyone has had this issue, but I'd love some help with it if you have advice.
For the three months (yes, months) my 2002 S60 with 176,000K miles has told me, with a CHECK ENGINE light that there is TRANSMISSION SERVICE REQUIRED. I know I should get it checked out immediately, but there hasn't been any issues driving it. I can't notice any gears improperly changing and everything has been running smoothly. The one *strange* thing that does happen though is that when the car is idle... say if I'm at a stop sign, the car will *sometimes* JERK forward a bit, but slightly...
I'm kind of at a loss as to why this is happening or if it's a big deal. I've had the car since 50,000K miles and everything that has been done to it has been at the Volvo dealership. HOWEVER, in December 2010 (at the Volvo dealership) I had the transmission flushed and about a few weeks later, the transmission light came up for the first time, then went away for a bit... so I feel it's related, but not sure?
Any help, suggestions? Or should I just bite the bullet and bring it in...?
Thanks!
-Andrea
Thanks!
-Andrea
Hi, all!
Thanks!
-Andrea
Thanks!
-Andrea
So you've had some issues for 8 months with your trans light coming on intermittantly and it's been on constant for 3 months straight and that is usually the computer detects a problem.
I agree with the above reply. Get your car to a shop ASAP.
But the damage is probably already done.
From what you described of the jerking, it could be just low fluid.
But it also could be time for some transmission work and or replacement.
Good Luck.
Good Luck.
Mycophiles
08-18-2015 02:36 AM
icehouse719
11-10-2010 03:31 PM
chrissygm
09-30-2008 05:53 PM
02, 2002, cost, forum, light, maintenance, reads, repair, required, s60, service, transmisdion, transmission, volvo, vovlo
