2003; Connecting Rod Bearings question
Old Jul 16, 2014 | 07:46 PM
EnvyOS's Avatar
Default 2003; Connecting Rod Bearings question
I recently purchased a new set of rod bearings for my Volvo, attached are the new bearings seated in the rod. Should there be that 3mm (1.5mm centered) gap? (Pushed to the left for example) It was like that with the stock bearings also. It just seems odd that there's that much left over room.
Regards,
Attached Thumbnails 2003; Connecting Rod Bearings question-20140716_174046.jpg
Old Jul 19, 2014 | 11:39 AM
dsharp's Avatar
The rod bearings on my 01 had a tang on the bearing that centered the bearing in the rod and the cap. But to answer you question the bearings aren't the full width of the cap. I assume it's to allow for the radius on the crank journal.
WJL
Feb 15, 2013 11:45 AM
kwkack
South
Oct 28, 2010 12:38 PM
tech
Sep 14, 2010 09:11 PM
Bobec
Nov 11, 2009 07:09 PM
McDub76
Jun 21, 2008 06:09 PM
