2003 S60 headlamp levelling motor
Old Aug 28, 2007 | 04:01 PM
kman1's Avatar
Default 2003 S60 headlamp levelling motor
I accidentally removed the headlamp levelling motor because I thought it was the bulb unit. Now I can't get the motor to clip into the reflector part. It looks like it's snap fit. Does anyone have a worhshop manual drawing to confirm? has anyone done this before ? I've been trying for ages. I attach pictures of the motor and a fuzzy picture of what I'm trying to clip into.
http://i3.photobucket.com/albums/y81...Picture006.jpg
http://i3.photobucket.com/albums/y81...Picture007.jpg
Old Aug 28, 2007 | 04:13 PM
billofdurham's Avatar
Default RE: 2003 S60 headlamp levelling motor
I hope this helps:
[IMG]local://upfiles/4491/FAB1DCC8EF7B4B0791EEA0BBD3383341.jpg[/IMG]
Old Aug 28, 2007 | 04:21 PM
kman1's Avatar
Thanks, billofdurham. I', trying to do the RH side and access is so tight I just can't seem to get it in.
Old Aug 29, 2007 | 12:30 PM
I should have asked which side you were doing and, of course, you are doing the side with further instructions.
If you haven't already done so detach the air hose from the control module housing to give more clearance.
Old Aug 29, 2007 | 01:30 PM
kman1's Avatar
I think it's kind of half in, two things concern me though one if i use the manual adjuster to set the height it's pops out and when it is in there is 3-4mm of free play in the reflector when i wiggle it whereas the other side appears to have no play in it.
Do you have instructions on how to remove the whole headlamp lamp unit? it may come to that.
Old Aug 29, 2007 | 04:27 PM
There should be no play so it is possible that you haven't quite got it right.
I have the instructions for removing the light unit but hope you don't have to go down that route as the front bumper has to be partially removed.Post if you need the instructions.
Old Aug 29, 2007 | 04:32 PM
kman1's Avatar
I've been messing about with this for two days, so it's the only route left for me. Please post the instructions - thanks in advance.
Old Aug 29, 2007 | 04:56 PM
Simple jobs have a habit of going pear shaped.
[IMG]local://upfiles/4491/83006129AD14424BBA39651DAE4A5BBF.jpg[/IMG]
[IMG]local://upfiles/4491/2A135B58E1A4476CBC3D6BFEBE91AC96.jpg[/IMG]
[IMG]local://upfiles/4491/89F2CBE70EE74E3EAD62E37F69673446.jpg[/IMG]
hockeyfool
2001-2013 model year V70
Oct 19, 2012 10:45 PM
sixtyfourford
May 25, 2012 12:35 AM
coyote12899
Mar 9, 2011 11:53 PM
gpweston
May 19, 2010 01:40 PM
greatyazoo
Jan 6, 2006 12:13 AM
