2003 Volvo s60 makes moaning sounds only when accelerating.
It only happens when the car is warm, about 5-10 minutes of driving. I found this thread from a guy whose problem sounds very similar to mine, but he got no real responses. (https://volvoforums.com/forum/volvo-...02-4-t5-30813/)
Does anyone have any ideas as to what could be wrong? Thanks.
The fan only runs when it is called for buy the temp of the car. It does not run all the time. With the noise make a short Vid clip and post it .This could be 100 things, or nothing but the turbo spool. GL
edit: btw, my car is turbocharged. I'll put a vid up asap.
u need to isolate the noise, suspension?? engine?? interior?? front engine cooling don't stay on all the time. u could test it be turning the a/c on then the cooling fan should come on within a min. afterblow is different, the use the interior blower fan. it only turns on when a/c being used, vehicle shut off after 50 min. then it comes on it own.
Tyronomo
10-28-2014 07:00 PM
98 Volvo S70 T5 Turbo
07-25-2012 04:53 PM
