2004 S60 2.5t stall? etm?
Old Aug 27, 2017 | 07:58 PM
alemedeir91's Avatar
Default 2004 S60 2.5t stall? etm?
I have a 2004 s60 2.5t awd automatic transmission. 170k miles
I just got from a family friend. For super cheap ran good for about 5 days and boom! Driving down the street using the manual mode and it stalled.... I got to the place where I was going was there for a few hours went home and it was fine... But now I try to start it.
It turns over idles for a few seconds and dies. I can hit the throttle and keep it going at 4k+ rpm soon as I let off it drops and dies....
I know these car have a bad problem with the etm/throttle body.. does that sound like the problem? I know it will mess with the idle and make it idle bad. But will it completely die out of no where? Just yesterday it was fine idling at 900rpms
Old Aug 27, 2017 | 08:51 PM
ssicarman's Avatar
Check the intake system for a pipe or tube that has come out of place.
Old Aug 27, 2017 | 09:31 PM
I tried I took apart the system from the place where the intake filter thing is.( Sorry new to working on cars I just shipp turbos) the pipe that goes from there to above the radiator. Then the few hoses that had a 3 way T pipe(this ends up in the manifold. The pipe that goes over the manifold and engine. But I did not take the pipe that sits in between the radiator and the engine( more to the passenger side and much shorter
Old Aug 27, 2017 | 09:36 PM
I hope it could be it. I took every thing apart to see if I could get to the throttle body just with tools at my house. I work at a shop but we don't really do petromechamics. More performance mainly I just ship turbos. And once in awhile help with a install of turbos or help with working on a diesel.
My car was throwing a throttle body code. Along with 11 other codes I didn't even see what they were. But there was no signs of a bad throttle body. Like bad idliling. Or anything just book it was done. I'll go back in tomorrow and take part the whole intake system.
Old Aug 27, 2017 | 09:54 PM
I'm so lost took it apart. Put it together..... I tried it it didn't work. Tried it 2 hours later.... It worked...
Old Aug 29, 2017 | 04:09 PM
jerick1976's Avatar
That does sound like worn contacts in the ETM but it's tough to say definitively from a keyboard. Xemodex can rebuild it and also have some troubleshooting docs on their page to help with the diagnosis.
Electronic Throttle Module (ETM) Repair & Return for Volvo | xemodex US
Old Aug 30, 2017 | 12:16 AM
JohnDC's Avatar
For a 2004 you can buy a Bosch ETM for around $325. Amazon even has them. 2002 and up do not need software update when changed.
Old Feb 25, 2019 | 05:31 PM
Elijah Cole's Avatar
Default Genious
you are a genius but how did you find out that 2002 and up don’t need programming
AJSERA
Sep 23, 2019 09:57 PM
Renato Centrifug
Sep 14, 2018 01:52 AM
tsbrett
Jul 13, 2018 11:01 PM
alemedeir91
Aug 28, 2017 05:42 PM
wolfspiritky
Apr 12, 2008 07:48 AM
