S60 Air Cond Problems
Old Aug 9, 2005 | 04:50 PM
danrashba's Avatar
Default S60 Air Cond Problems
A typical day with my air conditioner. Starts hard and cold for about 10 minutes.
Stops working and blows warm air
I flip it on and off a few times or turn on the defrauster and it sometimes comes back on cold for a few more minutes.....
Does the S60 have an internal thermometer that could be malfunctioning and telling the car it is too cold in the cabin and to turn off the AC??
Anyone have similar problems?
Thanks
Old Sep 1, 2018 | 01:25 PM
Cheeseman's Avatar
Re-shim the Clutch. Volvo clutch spacing is set at .040 where most A/C clutches are spaced at .020. The clutch is only pressing on the inside of the clutch plate (closest to the shaft). After the clutch ages it has difficulty engaging, by reducing the spacing the clutch plate will grab the whole pressure plate.
Old Feb 25, 2019 | 08:12 PM
baxter88's Avatar
Thanks
I had a similar experience and found the hi-pressure switch defective. Evap would ice and stop blowing cold. Thaws quickly as I am in SW Florida
Old Feb 25, 2019 | 08:31 PM
Cheeseman's Avatar
that would be a hard one to find. would act like a low charge cycling to a/c unit, but your gauges would tell you more about the charge. good find.
threat33
Sep 1, 2018 01:31 PM
djgiovanni
Jun 23, 2012 08:31 AM
1heistand
Jul 31, 2010 08:31 PM
timwu12
Mar 30, 2010 01:29 PM
trooperone
Jul 13, 2009 08:17 PM
