2004 S60 non-turbo excess crankcase vacuum
Old Aug 26, 2022 | 12:43 PM
Mundtquist's Avatar
Default 2004 S60 non-turbo excess crankcase vacuum
I have a new to me 2004 S60 non-turbo beater. I also have a 2004 XC70 turbo. I bought the S60 as a cheap non-runner. Now that it's running I have a crankcase ventilation issue. The symptoms are a whistling sound at idle and enough crankcase vacuum (suction) that it's a little hard to get the oil cap off. A Google search shows that it needs an oil trap. I have two questions, First, could it be anything else?, Second, do I need to change this immediately? Or am I ok to drive this while the parts arrive? If my XC70 failed the glove test, I would stop driving ASAP out of fear of blowing the cam seals, but with vacuum instead of pressure, should I also park it? It otherwise runs fine.
Old Aug 26, 2022 | 12:47 PM
usually the problem is too much pressure - ie the glove inflates, but start by replacing the oil separator (aka flame trap). that's the device that connects the intake air path to the crankcase.
Check out this vid.
MikeMac
Jan 4, 2015 09:24 PM
bigblockjoe
Apr 18, 2011 09:11 PM
cheesenacho
Oct 1, 2009 09:03 AM
proplasm
Jan 25, 2006 09:00 PM
proplasm
Engine & Internal
Jan 25, 2006 06:46 PM
