2005 built volvo s60 2.4litre auto. sedan
Old Jan 2, 2007 | 07:40 AM
jim's Avatar
jim
Default 2005 built volvo s60 2.4litre auto. sedan
Hello fellow Volvo owners, my enquiry is that my car vibrates/resonates when idling in drive gear. Only 10 000 km's done & engine bushes/mounts changed at 5 000 km's but no difference.
this vibration was more noticable after 4,500 km's travelled.
regards,
jim.
Old Jan 2, 2007 | 09:44 PM
Default RE: 2005 built volvo s60 2.4litre auto. sedan
Did they replace all the mounts?
There should be 4 of them.
Was there vibration after they changed the mounts?
Old Jan 6, 2007 | 03:31 PM
jim's Avatar
jim
Thank you for your reply,
all 4 mounts were changed and initially it seemed better but after another 1000 km's it seemed to be the same again. I was told to use regular unleaded fuel as i did not have the turbo engine.Should I be using premium 95 octane or 98 octane fuel ? I did use 95 octane fuel and it did not make any difference, in fact the engine would make knocking sounds when reved in neutral gear !!!
A friend has a wagon v70 auto 2.4 turbo and it is much smoother & less vibration idling in drive gear.
Would the injectors need cleaning ?
Old Jan 6, 2007 | 03:47 PM
Possibly the injectors need cleaning but I doubt it.
Sounds like something might be rubbing or touching somewhere.
Old Jan 6, 2007 | 03:49 PM
jim's Avatar
jim
Default RE:engine vibration idling in neutral only
s60 2.4 auto sedan vibrating while idling in neutral only.
recently engine mounts changed under warranty !
Is this common?
regards
jim.
Old Jan 6, 2007 | 04:03 PM
Default RE: RE:engine vibration idling in neutral only
There was also some problems with the mounts holding the Cat. Converter to the cross member.
rspi
Mar 13, 2015 12:40 AM
no6thgear
Feb 4, 2010 11:33 PM
raveman2473
Jun 17, 2007 03:27 AM
raveman2473
Jun 16, 2007 07:35 PM
