2005 s60 parking brake adjust?
Old 09-30-2010 | 08:44 PM
deary5280's Avatar
Unhappy 2005 s60 parking brake adjust?
How do you adjust the parking brake on a 2005 S60? Engages fine, just isn't full on until the lever is almost all the way up.
Thanks
Anyone able to advise?
Old 10-01-2010 | 08:23 PM
SVTfocusO3's Avatar
Yes, pull the boot up over the handle, not all the way. There will be a little cover that swings open, may be white in color, there you will see a nut, use a 10mm deep socket or whatever works. Tighten. 5-clicks on e-brake to full engage is good.
Old 10-01-2010 | 11:37 PM
nmikmik's Avatar
I'd recommend checking the parking brake shoes inside the rear rotors, just to make sure you are not riding it metal on metal. I still have to check mine, thanks for the reminder.
If someone (like your wife) drove it with parking brake on, you know the result
Old 10-02-2010 | 08:25 AM
deary5280's Avatar
Thanks for the feedback guys. I appreciate it. This is my first S60 plus it's a 5 spd, my old V70 was an automatic, never really used the parking brake.
jonathan1280
05-10-2019 02:44 PM
jef59
08-05-2015 09:14 PM
SgtCheeseNOLS
03-22-2011 07:56 PM
Counselor828
05-18-2009 10:58 PM
cudavid
12-10-2007 06:59 PM
