2006 S60 MAF Issue
Old Feb 22, 2014 | 08:48 AM
flmudshark's Avatar
Default 2006 S60 MAF Issue
109K miles and started having rough idle, stalling , etc. Threw P0101 and P0170 (MAF and Fuel trim, right). Unplugged the MAF and idle stabilized and car runs "OK". Replaced the MAF, cleared the code, and ran fine for 10 miles. Threw P0101 and P0170 again. Unplugged the MAF and again, ran OK. Installed 2nd MAF (warranty), ran fine for about ten miles and after shutting off engine, threw same codes again, runs ROUGH, stalls. Unplugged the MAF and runs OK. ????? Also noticed the PCV tube from the oil collector to the intake was broken, so temp plugged that thinking vacuum leak. Will replace that today. Help!
Old Feb 22, 2014 | 10:44 AM
damien360's Avatar
You should check the pcv system too while you are at it. That might become an issue as well not just the top hose.
flmudshark
Feb 22, 2014 08:39 AM
somedude
Jun 11, 2012 06:34 PM
leslied123
Mar 8, 2012 12:50 PM
6strings
Oct 11, 2011 04:55 PM
MookieB
Apr 11, 2011 08:01 AM
