2006 S60 whine before engine start
Old Apr 20, 2011 | 04:32 PM
wbachman007's Avatar
Default 2006 S60 whine before engine start
My s60 has developed a problem with a whining noise when I turn the key to the position just before I start the car. The noise remains when the engine is started. It sounds like it is coming from the driver side of the engine compartment. Has anyone had this issue before? If so what was the problem?
Old Apr 20, 2011 | 10:52 PM
J. A. Higgins's Avatar
Are you 100% sure the noise is coming from the engine bay? I only ask because a failing fuel pump will often emit a whining sound, but the fuel pump is generally on the right side of the chassis.
Old Apr 21, 2011 | 05:24 PM
MYS6T's Avatar
Vac pump Listen under the hood if it is coming from the air box area then check you vac lines for a leak.
searchlight55
Sep 28, 2014 08:42 AM
theequalizer
Oct 20, 2012 08:57 PM
andrewjc4010
Mar 22, 2011 08:02 AM
act1292
Oct 11, 2009 04:43 PM
dcox612
Dec 11, 2008 10:19 PM
