12V Outlet no power 2005 S60
Old Nov 27, 2008 | 11:12 AM
dornon13's Avatar
Default 12V Outlet no power 2005 S60
My fiance purchased an 05 S60 and neither of the 12v outlets have power. I have checked the fuses and none seem to be busted. After searching around seemed like #13 was the fuse for the outlet but this fuse is labeled telephone and only 5A which seems low to me for this application. I have checked this fuse and it is fine. I am really thinking this is a fuse issue and that I am looking in the wrong place but I am really not sure does anyone have any ideas? Oh and I know the key must be on for it to work. Thanks in advace
Old Mar 1, 2009 | 07:24 PM
billyjazz's Avatar
i have the same problem. did anyone come up with a solution to this?
thanks
Old Mar 13, 2009 | 02:04 PM
mrutherford2005's Avatar
try putting a multimeter on the plug and verify there is "0 volts"
if you get 0 volts, and the fuses are good, you have some other problem
adclark1966
Sep 17, 2016 04:31 AM
Jeff1967
Sep 23, 2012 09:52 AM
andyfilm
Mar 10, 2012 05:31 PM
vtwin_pilot
Sep 5, 2008 03:35 PM
Osamede
Jul 7, 2008 05:48 PM
