2007 S60 17" wheel offset +55
Old Nov 28, 2015 | 06:11 PM
kennyhwang's Avatar
Default 2007 S60 17" wheel offset +55
My car is 2007 s60, 235/45/17 tires
Currently 17x7.5" (Cassiopeia Wheel) inside look 7.5J 17 ET49
Centerbore: 65.1mm
Original Fitted On: 2001-2009 S60
I would like change to new wheel set
17x8" (Meissa Wheel) inside 8J 17 ET55
Centerbore: 63.4mm
Original Fitted On: 2011+ S60/V60
If I modification and widening Centerbore to 65.1mm,offset 55
has any problems?
Thanks so much!
Old Dec 3, 2015 | 04:47 PM
if you have a professional shop do the job the offset shouldn't cuase a problem. Keep in mind most cars now are "hub centric" meaning the center hub positions the wheel not the lug nuts. if you have the bore of the rims expanded, it'd have to be done by a machine shop that could maintain the center of the bore and not throw the rim off. Seems like a lot of work just go get a style. Did you search online to see if there are any aftermarket versions of the Meissa wheel with the 65.1 center bore?
Old Dec 4, 2015 | 12:05 PM
kennyhwang's Avatar
Thanks a lot!,
I know the Meissa wheel fit S60 +2011.
Kenny
Ripkord
Dec 28, 2018 08:28 AM
tv23
Feb 24, 2011 08:23 AM
Cyclenby
Feb 14, 2011 11:02 AM
Platinum52
Apr 17, 2008 06:10 AM
