2011 S60 won't start
Old 10-14-2017, 01:54 PM
arielu's Avatar
Default 2011 S60 won't start
So I just bought my Volvo used a couple months ago (no warranty). I tried jumping my car to no avail. Then I brought the battery to Walmart, and it checked out good at 12.49 V and 729 CCA (sticker says battery is 1/17 btw). Under the assumption that battery is indeed fine, does anyone have any thoughts on how to go about trying to resolve the issue myself?
Thanks for the help.
Old 10-17-2017, 09:12 PM
Vida's Avatar
Check your timing belt. Make sure it didn't jump teeth by an object. Check your oil level. Make sure it didn't seized.
Old 10-19-2017, 09:09 AM
PMOURASSA's Avatar
Sorry to hear,have you try to read if there is any Codes?
Old 10-21-2017, 04:21 AM
arielu's Avatar
Thank you folks for the suggestions. A day after I posted this I took it to my local volvo dealership. They ended up finding the inline fuses (part of the cables that connect directly to the battery) were both cracked at the weld.
Old 10-22-2017, 05:36 AM
Vida's Avatar
I've seen that once where it was jump started with opasite poles with a jump box. This one was the worst one since the other vehicle was giving a shot.
Old 10-22-2017, 05:38 AM
Vida's Avatar
I've seen that once where it was jump started with opposite poles with a jump box. This one was the worst one since the other vehicle was giving a shot.
trotter456
08-25-2014 07:03 PM
TXS60T5
06-13-2013 11:56 PM
discodave
01-18-2013 03:46 PM
Quick Reply: 2011 S60 won't start
