2012 S60 T5 - "High Enging Temp See Manual" warning message
Old Mar 14, 2019 | 11:05 AM
jamrock917's Avatar
Default 2012 S60 T5 - "High Enging Temp See Manual" warning message
Hello,
I have a 2012 S60 T5. I received the following warning message after the car was idling in Park for about 30min: "High Enging Temp See Manual" and "High Engine temp Reduce Speed" as seen in the pics i uploaded. I cannot find anything in the manual for the message and i've called 3 local Volvo Dealerships with no help. They all want me to do a $250 to $300 diagnostic test and say the issue could be a simple
This message comes up after idling in Park for about 30min
$50 issue to something more expensive. Has anyone else had this issue? It is the 1st time i've seen it.
Old Sep 21, 2019 | 09:03 PM
Darnell Huff's Avatar
Default Hello. I am having the same issue with my 2013 S60 T5.
I am having the same issue. Can anyone help put me in the right direction for an quick and easy possible fix.
Originally Posted by jamrock917
Hello,
Old Mar 18, 2021 | 10:45 AM
Farah's Avatar
Default High Temp
Hello,
Hii!! Did you find the problem and how did u fix them?? Helppp plsss
Old Mar 18, 2021 | 03:02 PM
Default High engine temp.
I found out it was my fan. Check your fan. I had gotten one for cheap from a junk yard and replaced it.
Old Mar 18, 2021 | 09:16 PM
Farah's Avatar
Default Thanks
thanks will check it out
Old Mar 19, 2021 | 07:45 AM
Your welcome.
Old Mar 19, 2021 | 09:42 AM
richardkonrad's Avatar
Its normally the sensor , you can check the fan by connecting 12v directly to it , disconnect battery and run a 12v to the fan direct if it fails then its the fan
Old Mar 19, 2021 | 03:30 PM
I totally agree. That's how I found out.
Angela Giannetti Snyder
Feb 10, 2025 02:11 PM
Doodle
Aug 18, 2019 09:20 PM
daveherns
Jan 16, 2018 03:13 AM
blagniceanu.mihai
Dec 14, 2016 07:36 PM
malaka
Aug 10, 2010 06:38 PM
