ABS issue or not..
Old Jan 5, 2014 | 01:15 AM
s60guy37's Avatar
Default ABS issue or not..
Question 1
Ok drove my s60 for the first time in the snow and when pressing the brake, the car will slide and my brake pedal will vibrate/shake. also can not really turn or come to a complete stop when this happens. Never drove a car that has done this but im guessing its abs?
Queston 2... my check engine came on, and i have no idea why(hoping its just a loose gas cap) but can i take it to any shop to get the codes read or do i need a special obdII volvo scanner. Are they cheap to buy?IPD ,VIDA
Old Jan 5, 2014 | 01:10 PM
mortenmorfar's Avatar
any scanner will be able to view the codes, it's required by law that the car manufactures give access to engine and emissions data.
And yes the vibration of the pedal is the ABS system working, and I would guess the reason you can't turn is because it's just too slippery.
Old Jan 5, 2014 | 06:12 PM
s60guy37's Avatar
When I turn the car on, the check engine light will flash about 5 times then stays solid. is that normal or does the flashing mean something serious? Happens every time i start car..
Old Jan 7, 2014 | 11:40 AM
Could be a misfire from worn plugs, or bad coils, get it fixed asap, or you could be looking at a new catalytic converter soon, and that's not cheap.
Old Jan 7, 2014 | 07:53 PM
oragex's Avatar
Originally Posted by s60guy37
Question 1
Only did so in the snow? So basically the abs is not working and the wheel locks or the brake pads are worn to the metal. Inspect abs wiring at the wheels, and brake discs/pads for wear/rust pits
Serge240
Mar 7, 2013 01:55 PM
piv15
Nov 3, 2012 07:56 PM
J Dubb
Jun 25, 2011 08:11 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
