ABS issues
Old Jun 29, 2024 | 04:27 PM
Buzz2's Avatar
Default ABS issues
Good afternoon to all. First time visiting site. I have a 2015 S60 Premier AWD. I am getting a ABS/ESC fai!ure notice. Went to a local tire service and they replaced the sensor but that didn't work. They are saying I need a new wheel bearing and want to charge me $625 . they charged me $98 for the sensor which I thought was fair but I am afraid that they may not know the actual problem. Also I am also getting a "city safety service required" notice and most importantly on occasion when I start the car and begin to leave the car has no power and will not accelerate so I stop and turn off the car and start it again and it is fine. I am hoping someone can help me because I cannot afford to bring it to Volvo deal or for repair. Look forward to hearing from you. Thank u.!!!!
Old Jul 1, 2024 | 03:01 PM
First step is to get a proper scan of the existing fault code(s) then clear them and see if it resets. If you are near a big box auto parts store, they may loan you a fully featured OBD2 scanner capable of reading ABS and chassis codes or pay the dealer or volvo friendly shop for the diagnostics scan. Its also possible that the non-dealer shop installed the wrong sensor type which would allow the code to reset. As to the wheel bearing going - the two may be related. Its possible some grease from the CV boot or bearing got on the back of the hub which will keep the sensor from reading correctly.
Check the forum for other posts on the "city safety" message ie:
https://www.volvoforums.org.uk/showthread.php?t=266682
Bcrary38
Aug 8, 2023 06:36 PM
cscaife72
Jan 22, 2023 06:40 PM
capnjim
Dec 1, 2019 06:42 PM
modifierwong
Nov 5, 2014 11:48 AM
George S80 99
May 15, 2009 10:13 AM
