AC Problems. Right smack in the middle of summer.
Old Jun 22, 2008 | 03:41 PM
sklater's Avatar
Default AC Problems. Right smack in the middle of summer.
Okay, I have a 2002 s60, 2.4 turbo, for about 6 months now. Got it in the middle of winter. Since the temperature has increased I have started using my AC more but have a problem with it. It doesn't blow very cold air and has very low pressure when blowing. I took it to a mechanic and found out that the freon was low, about a 1/2 pound low. So I had him refill it plus put in a dye to see if it was leaking or not. Well, I got in and it was blowing colder but still not much pressure. It sounds as if it is blowing hard but when you put your hands up to the vents it's bairly coming out. Also, the cabin air filter was pretty clogged so I am putting a new one in on Tuesday. So, right now I run it without the filter and still not much pressure. Even with both sides turned down the coldest and the AC turned up the highest. What might be causing this? It has about 92,000 miles. Thanks in advance.
Old Jun 22, 2008 | 04:21 PM
Default RE: AC Problems. Right smack in the middle of summer.
Is it manual climate control or electronic climate control?
Old Jun 22, 2008 | 10:36 PM
sklater's Avatar
It is the electronic climate control.
Old Jun 23, 2008 | 06:10 PM
The motors might need to be recalibrated.
Do you get alot more air if it is on hot?
Old Jun 24, 2008 | 06:29 PM
sklater's Avatar
Sorry for the late response. But today I did test it to see if it blew better in heat then in AC. And it did. Then Autozone called me to tell me my cabin air filter was in. So I picked it up and installed and and presto, problem fixed. Once I put it in it blows cold and also with much more force. Thanks for all the help. Doesn't appear to be any problem anymore.
darothwell
Apr 16, 2021 02:11 PM
speedster9110
Canada, Over Seas & Elsewhere
May 15, 2010 12:13 PM
Arsenal6
Apr 29, 2009 10:04 PM
axelm
Dec 2, 2007 08:22 AM
RedTurbo850
May 2, 2007 08:05 PM
