gearbox not lighting up without a smack
Old Apr 22, 2009 | 10:07 PM
Arsenal6's Avatar
Default gearbox not lighting up without a smack
850 GLE automatic...for u guys that helped with the recalls. After I got it done lately the gearbox doesn't light up right away...i smack it and the light comes on. Makes me suspect the dealership ****ed up sumwhere...
I was wondering if anyone has this problem and if so how do I solve it?
Old Apr 22, 2009 | 11:08 PM
Saleen9090's Avatar
It's easy to get under there and inspect the bulb. Need a walkthrough? You could also buy a cheap LED and switch to a new color if you're that enthused.
Old Apr 23, 2009 | 02:52 AM
Arsenal6's Avatar
could it be wiring? How would I check...a walkthrough would be nice if there is one...and what to look for in the bulb because it not burnt yet
Old Apr 23, 2009 | 07:53 AM
Psaboic's Avatar
I'm betting on a loose bulb
Old Apr 23, 2009 | 02:37 PM
Arsenal6's Avatar
So is there a walkthrough where I can check so I don't screw anything up =P
Old Apr 23, 2009 | 07:16 PM
I bet the bulb is going bad.
It is not all that hard to get the console out.
Lift the console lid in the bottom there is a cover with 2 8MM screws or t-25 screws. Remove them.
Then under the ashtray there is 2 t-25 screws going through the cover into the console. Remove them and take the panel out. Then down lower there is 2 t-15 screws remove them and then remove the gray and black plugs and the console will comeout. Then you can see the bulb.
Old Apr 23, 2009 | 11:53 PM
Arsenal6's Avatar
i will try and check it out this weekend thanks!
Old Apr 29, 2009 | 08:51 AM
Arsenal6's Avatar
I didn't get a chance to open up the gearbox area yet...but I had it happen to my climate control area the switch for the heater went out and came back with a smack ><
Are the lightbulbs dying or is it sumthing else?
Old Apr 29, 2009 | 09:31 PM
Bulbs dying.
Old Apr 29, 2009 | 09:57 PM
Arsenal6's Avatar
are they hard to replace? Or is it just plugging them in?
Old Apr 29, 2009 | 10:04 PM
The A/C ones you will need to remove the module and open it if it is the electronic module. If it is the manual it is not that bad.
JimLev
Nov 23, 2013 06:04 AM
steve79817
Apr 8, 2012 09:33 AM
Legendsecko87
Mar 25, 2009 01:34 AM
sklater
Jun 24, 2008 06:29 PM
Lszul
Jan 29, 2008 07:08 PM
