Access to underside of engine fusebox?
Old May 29, 2011 | 05:05 PM
btelzer's Avatar
Default Access to underside of engine fusebox?
The accessory sockets in our 2004 S60 no longer work, and I suspect that a fuse has blown. The cover of the fusebox in the engine notes that the accessories fuse is located on the "underside" of the fuse box. Only the "upper" side is accessible, and it appears to be bolted down. How does one access the "lower" side?
Many thanks.
Old May 29, 2011 | 09:58 PM
btelzer's Avatar
PROBLEM SOLVED. The fuse for the accessories socket is not in the fuse box in the engine compartment but the fuse box next to the driver's seat in position #13. Replacing that fuse solved the problem.
bobby v
Jul 28, 2011 05:25 PM
scorpius
Mar 22, 2011 02:11 PM
mdanzigmick
Dec 31, 2009 11:42 AM
b624333
Interior
Dec 31, 2008 03:51 PM
freelancewagner
Feb 14, 2008 01:41 PM
