amp wiring
Old Nov 10, 2010 | 06:29 PM
titaniums6025t's Avatar
Default amp wiring
yes i have searched this topic but found no clear answer. does anyone know if there is a good circut in the trunk area that i can tap into for my remote wire on an aftermarket amp? i had planned on installing a switch but it would be nice if i could find a key-on power wire to tap into that wont screw up my electrical system...any help would be appreciated.
Old Nov 10, 2010 | 08:07 PM
Racer_S's Avatar
I used the cigarette lighter/power outlet fuse(wrapped some wire areound the right side of the fuse and stuck it back in), but that's not in the trunk area...
Old Nov 10, 2010 | 08:52 PM
cordoba's Avatar
Doesn't your amps remote wire tie into the remote wire on the head unit?
It's been a while since I installed an after market system but that's the way it was wired. Otherwise the amp is always on when the key is on.
aben132
Nov 12, 2014 10:03 AM
sdl92
Jun 22, 2013 07:19 PM
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
huzzsaba
Apr 2, 2009 05:35 PM
