Back up lights not working
Old Sep 11, 2005 | 12:49 PM
merlin's Avatar
Default Back up lights not working
I was hoping somebody out there can shed some light on this. I have a 2001 S60, and my back up lights quit working. The bulbs are ok, and I can't find a fuse for this. Please help.
Old Sep 11, 2005 | 01:46 PM
Default RE: Back up lights not working
Are all the other lights in the back working alright?
It might be in the computer system.
Old Sep 11, 2005 | 02:48 PM
merlin's Avatar
Yes, all the other lights are working properly. I couldn't find a fuse for just those lights. I know in other vehicles I've owned, there were fuses for that. It's really strange both are out. Could it be some relay in the tranny or shifter that won't send the signal to the lights?
Old Sep 11, 2005 | 04:55 PM
The PNP/Gear position sensor is what sends the signal for the back up lights.
You did check all the fuses in the trunk as well didn't you?
Old Sep 11, 2005 | 05:06 PM
merlin's Avatar
I did check the fuses in the trunk as well. I can't even find one that is labeled for the lights. Is that sensor you mentioned hard to check or replace? Thanks for your help. Just trying to stay away from the money hungry service shop.
Old Sep 11, 2005 | 06:01 PM
For me the sensor isn't that hard to replace becasue I have done many of them.
It really isn't that bad.Look under the hood and find where the shifter cable mounts to the trans.The sensor slides on the shaft and bolts to the trans.
I don't have a wiring diagram to tell you the wires to check for signal.
Old Sep 11, 2005 | 06:22 PM
merlin's Avatar
Thanks for your help...I'll take a look at that
richardgrant
Apr 28, 2015 08:22 PM
rspi
May 15, 2014 07:36 AM
BigAdam
Oct 21, 2008 10:01 AM
m1964
Feb 25, 2007 12:04 AM
