Bang Bang When Shifting Gears
Old Jun 29, 2015 | 09:01 PM
netdvn's Avatar
Default Bang Bang When Shifting Gears
My daughter has a 2008 S60 FWD (T2.5) with 104K miles and for the last few months it makes a loud bang sound when shifting either to reverse or drive from parking or neutral. I replaced all 4 engine and transmission mounts but the sound did not go away. Both ball joints and wheel bearings are good. I don't see any leak or physical damage (by observing) when I checked the CV shaft's boots but I notice the drive shafts have more play than normal (when I rotated the wheels back and forth). Is there any trick to identify if a CV shaft is bad? I would greatly appreciate if anyone point me to a right direction to troubleshoot this bang-bang problem.
Regards,
Old Jun 30, 2015 | 02:25 PM
CV joints usually make noises (whining) or can clunk when the wheel is turned fully or when loading or off loading the torque. I think the fact you noticed some play is a good clue....
Old Jun 30, 2015 | 09:32 PM
netdvn's Avatar
Thanks mt6127. I'm going to fix it. Is there any recommended CV axle brand?
Old Jul 2, 2015 | 09:50 AM
netdvn's Avatar
Default Applying Metal Ahhesive to Front Drive Shaft and Hub
I took the car to local dealer for their opinion ($49.95). They found both CV axles and hubs are good. According to them, to fix the problem, both axels need to remove at the hub and apply metal adhesive to stop the noise - their price tag is $320. Since I know how to remove the CV axels, I want to fix it to save my daughter some money. Did anyone use a metal adhesive to fix the axels/hubs noise?
Dealer must use a special adhesive so that it can cure fast to operate the vehicle in a couple hours. I would appreciate for information about what type of metal adhesive and where to apply it. I don't want to apply to a wrong place and later on I can't remove the shaft from the hub.
Note: Dealer said, there is safe to drive the vehicle, just noisy when shifting from D-R or R-D.
Thanks,
Old Jul 2, 2015 | 12:13 PM
netdvn's Avatar
After did some research, here is what I found to fix the problem:
1. Remove axle from hub
2. Clean splines
3. Apply metal adhesive (Loctite 660) to splines
4. Reinstall axle
5. Let cure for 6 hours
janeofdrama
May 24, 2010 08:02 PM
sbrenton
Apr 30, 2008 08:03 PM
BigSection
Jan 22, 2007 09:36 AM
powers
Aug 28, 2006 02:35 PM
Mass850
Feb 11, 2006 12:06 PM
