Brakes are very Sensative on Cold Starts???
Old Dec 20, 2018 | 08:52 PM
jstein333's Avatar
Default Brakes are very Sensative on Cold Starts???
i recently purchased a CPO 2015 S60 T5 AWD (I5) and have had no problems. This week though I’ve had some weird on/off behavior from the brakes. On a cold start, sometimes (not everytime) the brakes are way to sensative, the littlest amount of pressure applied will cause the car to slam on the brakes, this is mainly around 15mph and under. Tonight I pulled out my garage and was shoved forward when the problem occured again. Of course minutes later the problem disappeared. Sometimes when the brakes slam, a quick warning will come on the screen and immediatly dissapear a second later. This wasn’t a warning regarding the safety systems though, I believe it said coolant/battery, but not too sure. Is this a known issue, and has anyone else had this, I’d really like to know what it is before I go to the dealer when it won’t occur for them and they won’t know what the issue is. Thanks!
Old Dec 21, 2018 | 09:32 PM
the coolant light could have come on because your level is lowest when the car is cold and the sharp stop sloshed the fluid enough to set off the light. In terms of the sensitive stops when cold, I'd be curious if you have a brake vacuum issue or just that the pads are very grippy due to some over night corrosion on the rotors. Does your car have an automatic braking feature and can it's sensitivity be adjusted?
Old Dec 21, 2018 | 09:49 PM
jstein333's Avatar
It does have the safety features, although I would think that it would flash the sensor display on the screen if it were due to that, or pop a warning on the dash related to the braking system. Next time the problem occurs, I'll turn off the city safety suite and see if it still exhibits the braking issue. It seems to happen very randomly, like one day every two weeks or so, but with temperatures dropping it might happen more.
fredgold52
2001-2013 model year V70
Jan 7, 2017 05:57 PM
squidskull
Apr 16, 2014 04:43 PM
nigel_miguel
Nov 21, 2012 01:48 PM
UpNorth
May 30, 2009 10:44 PM
amt
May 12, 2007 10:35 PM
