Break and Tran prob w/s60
Old Mar 6, 2008 | 10:14 AM
sgzenus's Avatar
Default Break and Tran prob w/s60
I have a couple of small problems with my 03 s60. First when I take my foot off of the break it sounds like it is still on the pad and makes a squeek/grind noise for the first couple of seconds after I accelerate. I have gone through a set of breaks in 10,000 miles. I think it is not releasing correctly...any thoughts?
Also, occassionally when I am accellerating at low speed the rpm's will go up and the car will not go for a second and then the tran would catch and be fine. It only happens once or twice a week.
Any help would be appreciated.
Old Mar 6, 2008 | 10:54 AM
jks2's Avatar
Default RE: Break and Tran prob w/s60
It sounds like a brake caliper is not releasing. Going through a set of brake pads in 10K is not normal. Need to take it to a mechanic and have them look at it. It probably needs an adjustment. Check to make sure that it hasn't warped the rotor also.
There is a software upgrade for the transmission that will most likely take care of the shifting problem. Take it to the dealer and have them do the upgrade.
ffmeltdown
Jan 17, 2012 05:54 PM
qvolv
Jan 17, 2011 04:47 PM
mbsjshad
Nov 6, 2009 03:33 PM
