bulb failure position light
Old Aug 4, 2008 | 08:26 PM
4sfire's Avatar
Default bulb failure position light
bulb failure position light comes up on message center. what is this?
Old Aug 4, 2008 | 08:30 PM
mrutherford2005's Avatar
Default RE: bulb failure position light
Funny, I was wondering the same thing. I think it is a marker light, I havent really cared much to investigate
Old Aug 5, 2008 | 06:54 AM
momS60's Avatar
In my experience, it's always been a bulb in the tail light - usually on the right side, center bulb in the lower clip (there are two clips, one high with two bulbs and one low with three). I've been through 3-4 bulbs there in the past year. Lots of bulbs to check, though!
Old Aug 7, 2008 | 05:20 AM
las4444's Avatar
I have over 120K miles in a s60 and they will wear you out with the position light. As a previous poster stated, it is almost always the rear red marker light. It is easy to check.Just wonder around the car and see which one it is. Oh, when you buy a replacement, buy three or four or maybe even five.
Old Aug 10, 2008 | 12:43 AM
Scott6's Avatar
There are 3 position lights on each side (as far as I know)
1 in the front on each side, its the same bulb as the blinker and 2 in the back, there the 2 small 5w bulbs top and bottom in the middle of the top light bracket.
Right now, none of my right side bulbs are working (something other than a bulb burned out)
dcb07
Mar 11, 2010 01:41 AM
Capo Cam
Sep 12, 2008 08:36 PM
etell221
Jul 23, 2008 01:41 AM
S60T5
Mar 24, 2006 02:32 PM
dreamcars80
Mar 28, 2005 03:04 PM
