A/C compressor cuts on when it should not
Old Mar 2, 2019 | 05:59 PM
rickhev1's Avatar
Default A/C compressor cuts on when it should not
I have a 2002 S60 with manual climate control. Blower off, Recirculate off. A/C off. Driver & passenger heat setting anywhere. Air distribution to floor. Frequently, the A/C compressor cuts on by itself. I press A/C off. About 30 sec. later, it cuts on again. I press A/C off. It cuts on again, etc. I have this problem about 50% of the time that I drive the car under the conditions described above. Usually, the temperature outside is moderate to chilly. I certainly don't need A/C.
Old Mar 3, 2019 | 10:57 AM
Is your vent set to the defrost/defog position? on some cars the AC is used to dry the air going to the windshield at the same time its being heated.
Old Mar 3, 2019 | 03:04 PM
rickhev1's Avatar
No, as mentioned above, air distribution to floor, 180 deg. from full defrost. But you're right, when it's on full defrost, the A/C is always on by design.
Volvo Crasher
Engine & Internal
Jul 29, 2015 07:53 PM
SaintCam
Jan 11, 2010 07:53 PM
frustrator-bolt
Aug 14, 2009 08:32 PM
trumpy
Sep 6, 2008 07:44 AM
Dads850
Aug 28, 2006 09:04 PM
