Can't Start Engine
Old Jan 2, 2007 | 06:18 PM
Chapiosh's Avatar
Default Can't Start Engine
Yesterday, when I wanted to go to buy some dinner, I got in my car, and tried to start it, and guess what, it didn't start.
The starter motor is ok, after a few tries, the car showed a "Reduced motor functions" I don't remeber well, but something like that was.
What could it be? First time it happens this to me!
Old Jan 2, 2007 | 09:22 PM
Default RE: Can't Start Engine
You need to get the codes pulled.
Old Jan 6, 2007 | 01:06 AM
Chapiosh's Avatar
Ok ordered today a OBDII scanner, in a couple of days should be at my house. My car doesn't have a check engine on, but just in case.
Old Jan 16, 2007 | 07:09 PM
Chapiosh's Avatar
Hi, I changed the fuel pump and the car started without problems, I took a test drive of about 40km without problems, when I got home, I went to take a bath, and when I wanted to start it again, it didn't start, and no fuel pressure is on the car. The older pump is ok to, so it isn't the fuel pump. what could it be?
No dtc codes on car, no check engine.
Old Jan 16, 2007 | 07:12 PM
Chapiosh's Avatar
I tested the cables that goes to the fuel pump, and they do not have electricity, checked relays again, changed them, checked fuses, and all are ok.
Old Jan 16, 2007 | 11:09 PM
Do any messages come up in the screen when it won't start?
Old Jan 24, 2007 | 04:49 PM
Chapiosh's Avatar
No, just the first time appeared that, I bought a new fuel pump, and put it on the car, the car started fine, but when i turned it off, the car didn't want to turn on again. Now no fuel pressure is on the car, so I took it to the dealer. They said that it was the fuel pump, and I told them that I just replaced it, and send them the old working fuel pump, so now they say there isn't comunnication from the car to the fuel pump.
Old Jan 24, 2007 | 10:09 PM
Maybe the rear computer went bad.(the one in the trunk)
Cleaner13
Aug 3, 2014 09:34 AM
ewgoforth
Jul 29, 2012 09:45 AM
Brennan.Messick
Sep 19, 2011 03:06 PM
yungprofit703
Mar 23, 2011 08:52 PM
MMAFIGHTER
Sep 2, 2008 08:43 PM
