Car Alarm Triggered Message
Old Nov 13, 2008 | 02:28 PM
jbnery6465's Avatar
Default Car Alarm Triggered Message
I have a 2001 s60, and this started about several weeks ago. Out of nowhere my car alarm would get triggered. I'll be looking out my window at the car, 1 minute its perfectly fine, the next the alarms just starts to go off (nothing inside and nothing around it). Is this a loose connection or something? I believe this is the factory alarm also. any help is appreciated, thanks in advance.
Old Nov 13, 2008 | 04:01 PM
Default RE: Car Alarm Triggered Message
Usually that means the alarm siren is bad.
Old Nov 13, 2008 | 04:26 PM
TIPSP's Avatar
Got Boost?
ORIGINAL: tech
+1
Same thing happened to my dads car...turned out the batteries insidethe siren were finished...leaking acid.
Old Nov 14, 2008 | 12:31 PM
jbnery6465's Avatar
okay, i'll have to look at that. is it as simple as replacing the batteries or the entire siren? Sorry i've never seen it so wouldn't know what to expect. And where is it located usually? Thanks
Old Nov 14, 2008 | 12:45 PM
vegasjetskier's Avatar
Normally you have to replace the whole siren. On S80s it's located in the forward part of right front fenderwell behind the liner - you have to drill out some rivets to get to it. I think the S60 is similar.
Old Nov 14, 2008 | 01:02 PM
TIPSP's Avatar
Got Boost?
Most sirenshave the sides heat-shrink (or what ever you call it), so it can't be serviced by the owner...we took apart ours by using a knife, and was surprised to find that even if you got it opened, the circuit board and batteries are covered in silicone glue.
Just buy a new one.
I believe the sirenis located inside the front pass. wheel-well.
nnj
Jan 11, 2015 10:38 AM
virgild
Mar 24, 2014 05:01 AM
mark188
Oct 4, 2009 05:50 PM
TomInTN
Nov 9, 2008 05:25 PM
MissingJenn
Jan 28, 2008 10:08 AM
