car just lost power and died
Old Jan 6, 2016 | 06:24 PM
peterz's Avatar
Default car just lost power and died
2001 s60t. 130k
yesterday I notice a little roughness while idling and driving, a little like misfiring. Car did not have normal acceleration power either.
I changed plugs and it seemed to be better but some of the roughness was still there.
On way to Autozone to have computer read I started to accelerate from a standstill after light turned green, but car would no accelerate. I was able to creep down the road about a quarter mile at which point car lost all power and died. It would restart, but immediately die again. Had to be towed.
Any ideas?
Thanks,
Pete
Old Jan 6, 2016 | 06:33 PM
Random's Avatar
Would help if you posted code that you were going to have AZ read, assuming your CEL was on?
Old Jan 7, 2016 | 08:52 AM
Cdubbs's Avatar
Possible vacuum leak(s) might explain the rough running. The car dying and not wanting to turn over is probably related to something else, maybe battery or alternator issues?
Old Jan 7, 2016 | 10:19 AM
RA082324's Avatar
Banned
You're gonna really have to get codes read for this one, so many things it can be. Check your battery terminals as well, always a good recommendation.
Old Jan 7, 2016 | 05:11 PM
could be several things ranging from a voltage issue to a fuel pressure / metering problem. If there are no stored codes (ie indicating a MAF or similar component issue) and the engine cranks at normal speed then I'd suspect fuel pressure. You can check/replace the fuel pump relay then check out the fuel pressure at the rail and test the pump's current draw. If all is good then it may be the fuel pressure regulator.
Old Jan 8, 2016 | 11:04 AM
MarcM's Avatar
Check your coils. I've been through pretty much the same thing. Coil #3 went bad on me. When I got the new coil, I went through and measured everything with a DMM (non-Volvo, but they must initially meet spec). You can find that information down in the thread here (2nd post up from bottom). Make note that the left pin # is for the black lead:
http://www.matthewsvolvosite.com/for...385240#p385240
It's a quick and dirty test. IPD (temporarily) no longer makes the HD coils, to which I would have certainly bought 5 of... but they're looking for a new manufacturer and are unavailable currently.
Marc
diesel_lv
Feb 11, 2015 04:19 AM
intrakitt
Oct 7, 2013 10:44 AM
Ahmed
Jul 4, 2011 06:55 PM
spankey
Jul 17, 2010 09:35 AM
spioana007
Dec 13, 2008 09:48 PM
